I did it by adding a 1pdt switch and attaching it like this to the lm386 leg 1. Just bend leg 1, leave it out of the socket and solder it to wire B and solder wire A into the socket. When leg 1 is switched out of the circuit there's no fuzz.
Just to clarify this, is this a SPDT On-On switch? And the middle pin goes to the bent leg 1 and either of the outer pins gets soldered to the corresponding pad on the pcb?
Your drawing is pretty clear but just wanted to confirm.
Thanks!
Thanks!
Great, thanks! I'm just starting this build and this a mod I definitely want to include.Yeah that's how I did it. You could use pretty much any switch. An spst on-off could be even smaller but I just used the simplest option I had on hand.
Cool. Thanks for the link! Looking forward to getting this completed and playing around with it.Most people recommend a vactrol vtl5c3, but it's up to your preferences. I decided to try a few different options, I ordered some fake chinese vactrols for like 3 bucks and also made some of my own. I ended up going with a 5mm red LED and this LDR from pedalpcb https://www.pedalpcb.com/product/gl5528/, but I tried all of the LDRs they have here and all had similar results. I might swap it out for a real vactrol if I get one as part of an order so I'm not paying 5 bucks shipping on a tiny component; or if I find myself using the pedal more often.
I may get some heavier use out of it soon. I've been toying around with it more this past week since the LDRs just arrived and I swapped my old one for the Gl5528 and found some really good settings I found that if you keep the fuzz on and turn the depth and tracking knobs all the way to the highest modulation setting , it actually cancels out the delay and the blend no matter what you have delay and blend set to. So you get a weird, random wobbly, lo-fi vibrato type effect in almost realtime (it's delayed a few milliseconds)
I love this picture. It's perfect.I did it by adding a 1pdt switch and attaching it like this to the lm386 leg 1. Just bend leg 1, leave it out of the socket and solder it to wire B and solder wire A into the socket. When leg 1 is switched out of the circuit there's no fuzz.
Hey, I'm very new to this board but recently built the Chalumeau (first PedalPCB build and third overall build after doing a couple of Madbean PCBs)I did it by adding a 1pdt switch and attaching it like this to the lm386 leg 1. Just bend leg 1, leave it out of the socket and solder it to wire B and solder wire A into the socket. When leg 1 is switched out of the circuit there's no fuzz.
Yeah, I did the mod without the switch and it worked fine, just modding it to take out the fuzz. But as soon as I wired the switch up I lost all sound through the circuit. Bypass still works of course. Really not sure what happened. Haven't had a chance yet to revisit but will have some time to work on it tomorrow.I have this in the mail. Someone gave me the schematic because I had the same question as you. Can’t verify that it works but I can see no reason why it wouldn’t.
I’ll let you know how it goes if you like.
