Chaos Machine Ticking???
K Pedals
Haven’t seen anybody post they had this problem... when in bypass the chaos machine is ticking in time with the rate knob?
Any ideas??? I’ve tried moving the input and output wire the only thing that seems to affect it is the right expression jack.?.??
zgrav
try rotating the two inner jacks to put both sets of wires toward the sides of the enclosure instead of the middle to see if the wires are picking up the noise as they go across the pots.
