Chickenhead - Bias
FormulaFourteen
Hi gang
About to build a Chickenhead.
Can someone talk me through setting the bias using the trimmer?
(even better, can someone point me at any pedalpcb docs that explain it, if they exist - teach a man to fish, etc etc).
I actually have the same question about the Clandestine Preamp but for the benefit of future searchers I'll post them separately.
Thanks
Set your DMM to measure voltage (20V range).
Attach the DMM ground to a ground point on the PCB.
Measure against the collector of the transistor. On the board, it's the right-most pin of the transistor. The tab is for the emitter.
Socket your transistors if you're not a seasoned pro, and you will thank yourself later.
