The Gator
I want to make sure I understand the biasing method for this new version of the chop shop circuit.
The sag pot turned all the way CCW (should make it lowest resistance reading) then measure from the provided pad on top of the trimmers. Measure from the pad to ground I assume. Fine tune each trimmer until 6 to 6.6v is achieved?
I did this and the pedal works. However turning up the sag pot just cuts the sound out rather quickly. It was also very, very touchy to tune in the trimmers. It goes from .4V to 7.4V when I barely touch the trimmer.
It gets extremely loud, but not much drive.
I need to make it clear that I used some 2N5458 jfets in place of the J201 jfets.
I also used a TO-92 package 2N2222 instead of the TO-18 metal can type. I was careful to examine the pinout. The hfe on this 2n2222 tested out at 410. Little higher than the metal can spec, but not much.
