Circulator Phaser
Many__Of__Horror
Really good sounding phaser (not that I have a lot of experience with them). I had some issues with the dual LED this version of the PCB required but worked around it with the help of Chuck on the forum. Got the LFO working with a single LED, and offboard wired a second single LED for the effect indicator. Both LEDs turn off when the effect is bypassed and both come on with the LFO flashing at speed indication when activated.
Didn't have the knobs I wanted in stock so just threw some spares I had on it, but I kinda like it this way now.
As usual I had way too much wire length left over, but the neatness is something to work on.
I get them from Amazon.
https://www.amazon.com/gp/product/B013JRWCBU/
I like these because the female connector is small enough to pass thru the 5/16" hole (and nut) for the power jack. Means you can pre-assemble the cable to the jack before installing it in the enclosure.
They also have some cables with larger connectors and silicone insulation on the wires.
I use those all the time. Makes assembly and disassembly much easier.
