Combining two effects in one enclosure
thedwest
Not sure if this belongs here or in general questions but I am taking a stab at trying to combine the Starboard Fuzz and CrackleJack in one enclosure so that they can be used independently or in tandem from one power supply. Using the breakout boards for the footswitches, would the wiring in the picture below work or am I way off track? Thanks!
302
You're close. You don't near as many power/ground connections at the top, and I wouldn't run the Input / Outputs in parallel like you have them drawn.
This is how I would do it. This will allow you to run the Starboard Fuzz into the Crackerjack if they're both turned on simultaneously, or you can run either independantly.
Sorry it looks rough, I'm not at my computer where I can do it properly.
303
That's how I do it. If you want to add a switch so that you can change which effect comes first you can use a 4PDT switch to change the order:
can you wire say an overdrive and a eq or boost in series using one switch ,the out from one pedal going to the in on the other pedal as above and the out from the pedal on the right going to the out jack and the ground points joined , the +9v going to the dc jack individually ,only one foot switch for both pedals
I want to avoid two switches the pic shows two
I''m going to give it a go- how I said one switch ,just finished the Mark11 tonebender tried it with the Mark 1 tonebender really nice together, once I finish a Julia chorus I''ll give it a go.
Is it correct to assume that looking at the second post, the leftmost effect is first in the signal chain, followed by the rightmost effect, before the signals exits the pedal?
combo-jpg.303
