Compiling on Ubuntu worked!
Dali
Finally on a third environment, I was able to get tcpoint's code compiling from the source.
Even changing delay time from 1second to 5 worked. (I'm such a hacker ;) )
I compiled on Ubuntu 16 inside a Virtualbox machine, then copy the BIN on my Mac and then ES-Web programer to upload to Seed-Terrarium.
I'm very happy now!
Well, after your success story, I can also now compile successfully on Linux. Granted it's a PITA because I have everything on mac, but I did confirm the unmodified tcpoint verb worked, and my sloppily modified multidelay works as well.
I'm also a hacker and added an extra delay on so it now uses 4 delays and all 6 knobs.
For the record I'm using 18.04
Hopefully, you guys will have made it work on Mac by the time I receive my pcbs and build my Terrarium ;)
Non.
:p
But frankly I don't see anything in tcpoint code that looks "Linux-only" related so it's possible Libdaisy or an external library like the "arm-none-eabi-gcc" has a problem not currently in the Linux version. I'm clueless.
As long as the only Terrarium-ready code available is from tcpoint (and thanks a lot for that!) I feel a bit in the fog...
