Mike McLane
This is definitely a Chuck question. How much signal boost is on tap with the Level control of the Delegate (Boneyard)? I bring it up because the General Tso you helped me with had a Level and Tone controls which caused me to think what a great "boost" pedal it would make (before I burned it up with some part experimentation ) . . . the Level provides signal boost, the Tone provides subtle shading and you could dial in compression as desired. I'm going to go back to the well with your Delegate design and was just curious about signal boost.
