Conqueror Fuzz - Can I make it a bit louder?
Idlebeach
Howdy! I just finished building the Conqueror Fuzz and it sounds pretty darn neat. The only thing I would like to change is getting unity volume at least a little closer to noon. Right now I would say its around 2:30-3ish? Give or take. Not sure that it's going to help but I think that's the ballpark I am in now. Just incase it matters at all I did use a transformer instead of the inductor. I assume that is probably what gives it the cocked wah type sound and may not have much to do with volume though?
I assume there are is a resistor or 2 I could swap, or would a pot value/taper change do the trick? I am open to suggestions. There are a ton of people way smarter than me on here so I hope someone can fill me in! Thanks a ton!
Bricksnbeatles
If you’re fine with the maximum volume on tap, but just want unity to be closer to noon, then you can just swap the volume pot with a 25k linear pot.
Chuck D. Bones
The White Box should really have a booster at the end IMO. Check out the Mystery Machine, Castledine did it right!
The Wah inductor and transformer will definitely sound different.
Idlebeach
Oh wow, I never noticed the Mystery Machine. Maybe I will try that down the road!
What kind of differences would it make? Maybe I should order an inductor and try it. I noticed there were different colors available that were supposed to sound different as well.
Idlebeach
I did the ol' swapparoo. It did help me get it a bit closer to where I wanted it so I think this is going to be the "fix" I go with. I ended up being pacified enough to box it at least!
Chuck D. Bones
The inductor is high-Q and the inductance tolerance is pretty tight. The transformer is low Q and the inductance is not specified, so you get what you get.
It's like the difference between Thunderbird and a good Cabernet.
