Could PedalPCB Intelligent Relay modules be used with DIY VFE pedals?
BPFuzz
VFE's switching on the latest versions of each pedal included switching code that he couldn't release with the DIY files. Rather than going back to previous versions of the DIY pedals that didn't have relay switching, or messing with the board layout/schematic (if you even need to), Can PedalPCB's switching modules just replace those for the same functionality?
I'm not an engineer, and haven't made any pedals with relay switching before, so i'm pretty clueless about the options available.
Bricksnbeatles
I believe you can as long as it’s not a circuit that needs the bi-polar power or something else like that. You can get the IC with the preloaded code by itself from Madbean now tho
BPFuzz
I forgot that Madbean was selling the pedals as well. I'll have to take a look at the two and see if it's compatible. Thanks!
