Covert Overdrive vs Tweet Man Overdrive Volume
stevtron
I noticed a significant volume difference between these two builds.
The Covert got a lot lesser volume than the Tweet Man . Is this normal or could it be, because I used ceramic capacitors (covert overdrive) for the 680nF instead of plastic film as usual ? It's not really a problem at all, but I was thinking about ...
the type of cap should not affect the effect volume. could be normal for those two effects to have different outputs. ideally they will each let you match the level of the bypassed signal, and more if you are using them as a boost.
