Creamery Buzzing
IPv6Freely
LED comes on, but there is nothing but a low volume buzz through my amp. Another day, another pedal that doesn't work...
Board pre-pots:
Solution for pots not having pins narrow enough to fit into PCB holes:
Final assembly:
Do you see anything obviously wrong?
It really is Wurth going over the PCB thoroughly & and checking orientation if it doesn't fire up!
That IC 4 looks suspect the way it's sitting.
How did you determine which way THAT 2159 goes?
That's a good question. I guess I should check the datasheet on the THAT2159 because I have no idea and made an assumption there.
I'll take a look at IC4
