I thought that may well be the case signal getting dumped to ground but also thought it might be a layout updateIf the diode is reversed you will short your wet signal to ground.
That’s a green led that was connected to pin 7 in order to solve the noise issue. There is a good thread where a user solved the noise issue by connecting these up. I thought that was the problem initially, so I clipped the connection to pin 7, but have left the led connected to ground in the interim. The led legs are not touching any pads or the like, so shouldn’t be causing an issue. Unless someone points out it’s a problem? No issue to remove itWhat's that sticking up amid the Pots on the left?
Ac on the DMM is the v~?Pin 5 is an AC square wave. Check it with DMM on AC and see what it is. Recheck pin 11, 46.2 is a wee bit high. Pins 11 and 12 are the voltages that are off.
Not that this is in anyway helpful, but no, I haven't managed to fix it.I'm running into this same issue, did you figure out what the problem was?
No worries man. I'll update if I can figure anything out, maybe we have the same issue.Not that this is in anyway helpful, but no, I haven't managed to fix it.
I've put it on the shelf and moved onto other projects to build back some enthusiasm in tackling it
Appreciate the help dude.OK, These readings look correct. Pin 5 is not used in this circuit and it should fluctuate between 0 and roughly 5V. Pins 13 and 14 are not used either, that's why those are a bit strange. Everything else looks good. Pin 1 is Power in, +5V. Pin2 is internal voltage, the PT2399 cuts the +5 in half and runs on 2.5V. Pins 3&4 are grounds. Pin 5 not used. Pin 6 is the oscillator input from the LFO, its always 2.5V. Pins 7&8 are grounded through the 100n caps, so a low voltage is good. Pins 9 through 12, 15 and 16 are inputs and outputs to your circuits and the bias voltages are correct. The PT2300 seems to be working. Check Voltages on IC1, IC3 and IC5. IC1 and IC5 are referenced to 4.5V, So that voltage should be a common value on them, With exception to Vcc and GND. IC3 is referenced to ground, so besides Vcc and GND, your readings may be at or near zero. Post the readings when you get them.
