Finished this build tonight. Really great delay and so many weird little ambient things you can do with the modulation section. This was a pretty straight forward build however it is a pretty tight layout and soldering the pots on the bottom row took some serious care to avoid melting caps.
decided to go with a straight to copy of the Space Spiral. The pink led looks great.
at the longest delay times I get a little distortion on the trails. It’s faint but enough to be slightly annoying. I might swap the pt2399 and see if that helps any. From what I’ve seen this can happen at longer delay times with the pt2399 which is why the cataclysm delay has the tone control.
