Hi all,
I've clearly bit off more than I can chew, but I'm being stubborn about it. I ordered the Dark Rift kit from www.musikding.de (there is some diffrences in the components and the PDF I downloaded from this site) and jumped head first into my very first build. Last night, I burned up a 9v adapter and overheated a 9V battery before I decided to stop for the day.
I managed to fix the problems with power (did I maybe burn up a component? not sure how to check this). And I have sound in and out. The bypass works. The delay works (time know), the repeat pot goes crazy even with a small turn. The mix know seems to work. All the modulation knows are off in some way and ther is noise and a click with the modulation.
The LED won't turn on...
I am hoping that someone has a good eye and can see something stupid I may have done, or point me in a good direction for troubleshooting. Like I said, this is a first build (I know, should have started with something smaller), and the soldering is not that pretty. I've checked the connections as best I can (especially for shorts and continuity), but I'm not sure where I should really be looking. Is there an order for how to debug a board?
Pictures are attached. I can probably try to record the sound if that might be of any help.
I'll keep trying on my own. Should I take everything apart and start again?
Any help would be greatly appreciated.
What a great way to spend an afternoon (or two or three)...
