Jbanks
I normally use a 2.1 DC jack that is the “standard” size. See on the right in the pictures below. What you’d get from Tayda.
I’ve bought the Lumberg style DC jacks (On the left) from PedalPCB so it would 1) fit his pre-drilled enclosures 2) allow me to use the 3in1 DC board to power multi effects pedal projects.
my problem is with the center pin. It seems too fat so that the pin can’t go in. Do you really need a different sized power cable to use only this DC jack? That seems really impractical, but I’ve seen weirder things done.
Any feedback on how people do that? Is it a VHS/Beta choice you make to go one way or the other? It seems weird that out of the dozens of pedals I’ve built and owned, that it doesn’t fit the power and drives me nuts!
thanks in advance!
James
thanks in advance!
James
