Hi! How can I add a mix control to delegate comp?? Thanks!!
Z zgrav Well-known member Dec 28, 2020 #2 probably not an easy way to do that. if you haven't built it yet, pick another design that includes a way to blend in a dry signal. the 4:1 compressor from Madbean is a solid performer: https://www.madbeanpedals.com/projects/_folders/1590G/pdf/FourOne.pdf
B Boba7 Active member Dec 29, 2020 #3 zgrav said: probably not an easy way to do that. if you haven't built it yet, pick another design that includes a way to blend in a dry signal. the 4:1 compressor from Madbean is a solid performer: https://www.madbeanpedals.com/projects/_folders/1590G/pdf/FourOne.pdf Click to expand... Favorite comp ever! (Ive tried a lot)
