Diode substitutions.
Radkins80
What are the sound differences between different clipping diodes. I am moving on to a Distortion 250 build and I am out of 1n270 diodes but have a good supply of 1n4148 diodes. Anyone ever made this substitution before?
similar questions have shown up before, believe it or not. : ^ )
search the forums for discussions about diodes for lots of info.
I used silicon diodes in 250 overdrive (don't recall if they were 1n4148 but most likely). Sounds good to me.
I think if you build it to 250 specs, the original used silicon, while the Dist+ used germanium.
You’re correct, the Distortion + used 2 X 1N270 diodes, while the 250 used 4 X 1N914’s. I recently built a Distortion + with the 270s. So I did all my homework on the 2 since they are the same circuit. For how simple it is, it’s a great distortion pedal. There are also a few resistors and caps that are different between the Dist+ and 250.
