vigilante398
Authorized Vendor
Alright, I kind of teased this one a bit ago in the Echo Foxtrot thread as this is the reason Echo Foxtrot has been discontinued. Diplomat is based on the EF86 channel of the Matchless DC30, my favorite amp ever. Since this is a single pentode stage it will not overdrive by itself, but you can put a boost or drive before it to push it, or you can use it as a clean boost to push something else.
It's a pretty straightforward build, especially if you've built anything else by me before, and it uses the same general setup as Particle Accelerator. It has two controls: a master volume, and an 8-way rotary Tone selector. The original only used a 6-way, but I went for an 8 partially because they're more common and partially because I wanted to add some extra values to make it work better as a bass preamp.
I have a couple dozen boards on hand and ready to go and have some enclosures being milled now, but I still need to finish getting the build doc put together before I can list them for sale.
It sounds fabulous, especially driving another tube preamp (my use of choice) or being driven with another boost (still very good). I will mention it's very loud, but obviously there are steps that can be taken to tame it down a little if you don't need to push a power amp. I have a handful of NOS EF86 I picked up, but I have probably 50 or so "winged C" 6Ж32П so I use those most of the time.
