Do you prefer the Simulcast at 9V or 24V?
  • 9V
    Votes: 15 51.7%
  • 24V
    Votes: 14 48.3%
  • Total voters
    29
PedalPCB
Administrator
Staff member
A common modification for the Simulcast project is to omit the charge pump and run the circuit at around 9V, like the original Hudson Broadcast.
I'm curious to know how many are taking advantage of the charge pump versus how many are bypassing it.
(Talking of the Duocast) I use it depending on the stack, but if I didn't have the option then I doubt I'd miss it.
I use my pedals almost exclusively in reamping scenarios so it entirely depends on what happens to be working in the mix. I'd say I use both modes equally tbh
Yeah. I had to set it aside a few months ago but from what I remember, the squeal only went away with super low gain settings, and was pitch modulated by the low cut
I had a squealing problem (not pitch modulated) and it was a dodgy charge pump. It was a 7660S but just didn't play right (it worked ok in another pedal). After swapping it around the squeal was gone.
I love the charge pump!
9V dirty channel = nasty splatty fuzz, 24V clean channel = glassy clean boost, 24V dirty channel = surprisingly good distortion
Probably use those three settings pretty equally.
There an advantage besides cost to leaving the pump out? Smaller footprint? Is it part of why the 125B DuoCast is on hold?
I include the charge pump but I usually use the 9v setting. I want all the grit but at a lower volume 😂 Don't want to wake up my kids.
The option to not include the charge pump and transformer would be great. Some solder pads to jumper if you're making a new revision.
I can't tell the difference without the transformer, and it's a non-standard part (at least for regular builders) which raises the build price significantly.
I made a vero build of the “Broadcast”, and at first put in the ‘magic’ transformer. Then I tried a red Fasel inductor, and I couldn’t tell a difference!lol
