cgmason1986
Some days things work, some days they just don't. I am working a klone build, I finished it this morning and it worked great for about 15 minutes, then there was a quick fade in volume/gain and I've traced it back to the dual pot. Testing with my multi-meter, on the upper set of pins - instead of going from 0-100k, it goes from 0-20k-0. The other set of pins on the dual gang work fine. I thought maybe it was a bad pot so I swapped it out, checked the old one once out of the circuit and it worked fine. Sounds like some kind of grounding issue, but isolated to just this control?
These are the build docs:
Just a standard Klon KTR circuit
