andare
I just finished my Duck Box. It doesn't quack enough and only on guitar. No volume drop. Bypass works.
The Attack knob must be maxed out to trigger a decent effect and the filter only opens up if I play medium to hard. My Strat has vintage aka low output pickups.
The Decay knob seems to behave normally, the higher up the longer the decay of the envelope.
The Blend switch also is normal, down it's just the effect (pretty dark and kind of distorted) and up it adds the dry signal in.
On bass, which is what I built this for, it sounds horrible. It adds volume and distortion, it makes the tone muddy and the filter only opens up a tiny bit if I go medieval on the strings. I tried a few P basses and a Bronco with a dual blade humbucker wired in series. Same deal. Completely useless.
I used the 22n cap for C13.
I socketed the transistor and then soldered it to the socket because it was a bit loose. No changes in sound. Or have I fried it?
My power supply reads 8.99V.
Q1 emitter reads 0V, the base 0.371V and the collector 0V.
IC voltages:
IC 1
1: 4.32V
2: 4.38V
3: 4.38V
4: 0V
5: 4.38V
6: 4.38V
7: 4.38V
8: 8.75V
IC 2
1: 4.40V
2: 4.40V
3: 4.21V
4: 0V
5: 4.38V
6: 4.39V
7: 4.39V
8: 8.75V
I checked the resistors and they seem to check out.
IC voltages:
IC 1
1: 4.32V
2: 4.38V
3: 4.38V
4: 0V
5: 4.38V
6: 4.38V
7: 4.38V
8: 8.75V
IC 2
1: 4.40V
2: 4.40V
3: 4.21V
4: 0V
5: 4.38V
6: 4.39V
7: 4.39V
8: 8.75V
