Harry Klippton
What does it ...do? What are some applications of this pedal?
But the real question is, can the new you go to work for you, and let YOU stay home and jam all day?I connected mine to a looper and delay which spun off both a new timeline and sequel to groundhog day. That's me....yesterday....over there. Apparently the "other" me does selfies with Phil, but not Conners.
Would it be possible to mod it by wiring in a pot for each loop?Yes it's two independent true-bypass loops. You can activate neither, one or the other, or both.
It doesn't "blend", but they're in series with each other. (eg: if both loops are active the signal goes through Loop A then through Loop B)
https://forum.pedalpcb.com/threads/what-jacks-to-use-for-dual-effects-loop-switch.6623/#post-55961Is there a good B.O.M. for this project? Maybe Tayda links, like the Auditorium kit? Thank you so much!
Sure, but... What are your needs? What do you wish to accomplish?Would it be possible to mod it by wiring in a pot for each loop?
