Duocast 1590BBM build
jcrhee
Here's my Duocast build. I had the version 1 PCB so had to use a combo of solder lug and PCB lug pots to be able to use the Neve style knobs.
I spray-painted it with RAF Blue-Gray -- although it looks more navy blue than gray to me. I found a laser name tag engraver off Etsy to do my custom label.
Other than that, a straightforward build with BC549C and GT2308 Germanium transistors.
Oh, I think I used too much hot glue on this one.
Very nice, very clean. How do you like the JST connectors? I've used them a few times.
How does it sound?
How does it sound?
those are the molex connectors -- I used a right angle one for the DC and straight for the LEDs. Love them but take it with a grain of salt as some PCBs can't accommodate them. Small bear sells them. They even offer the cables that are pre-crimped.
The Duocast sounds really good. I love the light fuzz that I dialed in for the standard mode. The extra gain boost is a tad sharp to my ears but it definitely cuts through the mix. I also noticed that the low-cut pot is very subtle with low gain. You have to crank up the gain for it to be noticeable.
Another great build! This is next on my to do list and the enclosure arrived today. I’m going to use an engraved plastic name plate too. Looks awesome and very professional.
yeah I highly recommend it. Let me know if you need any Etsy shop recommendation. The guy I used is based in Canada but the dude was super responsive and nice. His price was also competitive.
Did you use the Rev 3 drill template in the PDF?
Just curious if those knobs fit the spacing.
I actually didn't use the Rev 3 drill template. I just mocked it out on Affinity designer and translated that to the enclosure.
This obviously is not scientific in the slightest, but it looks like rev3 would actually fit the Neve-style knobs:
It should, larger knobs was the reasoning for spacing the pots out further but I haven't had a chance to verify it against those particular knobs yet.
I used the datasheet for those for the measurements though, so I certainly hope they fit.
@PedalPCB I have a spare board for the DuoCast, but there are no revision markings on the back, so I'm assuming I have rev1? Otherwise I could try building a new one with those knobs.
here's my affinity designer file for anyone that wants to compare or use.
Excellent, very helpful. Your pots are spaced approx 1.116", the rev 3 board is spaced 1.15", so that should do it. :)
@PedalPCB are new orders for this board guaranteed to get rev3?
I'll double check for you in the morning, but I'm fairly certain all of the rev 2 boards are gone so all shipments would be rev 3.
