In two recent builds, I have had issues with a loud pop when the pedal is activated or deactivated. One build was a reverb, and one build was a 4-channel buffer for a studio application, so technically I've had the issue 5 times.
In each case, I observed DC voltage (0.3v~0.5v or so) on the PCB output, despite the presence of a properly wired pull-down resistor after the capacitor. In each case, I replaced the electrolytic cap with a film cap, and the voltage (and pop) was gone. One project used 1uF and the other 10uF, so it wasn't just a single value of capacitor.
Has anyone else experienced this? Are electrolytics generally more prone to DC leak? Or, does this sound like just bad parts from Tayda? If so, do you recommend another supplier (I'd probably start with SmallBear since I order stuff from them a lot already)?
