orangetones
1) So, I have just finished up the Electrovibe. I get different intensities with each speed setting. Like if I have it on speed 1, it is less intense (can actually see the bulb change intensity) than when on speed 2 (given the same speeds). Why would the bulb driver be affected with the different speed settings?
The other issues are as follows:
2) Even with the volume maxed out, the effected signal is lower than unity.
3) When in vibrato mode, it is much louder than in chorus mode. Is this typical?
Additional info is that I get slower speeds with the speed pot 2 than speed pot 1. Differences in potentiometers? Could this be affecting the bulb driver brightness in the different settings?
