Eqd Arrows Boost
CanadianDave
I haven’t posted anything on this forum in ages, cause I’ve been busy with a lot of projects.
Covid has me laid up for a week, so here we go…
This is my EQD Arrows boost. It’s powered by a 9v battery that charges via USB. One toggle is the bypass, and the smaller cuts the 9V power, so it doesn’t drain power when I’m not using it. As a bonus, if you cut the power while it’s ON, the draining power in the capacitors gives you about 30 seconds before the sound fizzles out and fades to silence. Kind of a cool way to “fade to black.”
I cut a panel to cover the battery, but you’ll see the usb charging port (I still plan on making a cover for the port)
Enclosure: hand built Fender Meteora clone.
- Fralin P90, and a Mojotone gold foil pickup.
- Swamp Ash Body
- Quarter sawn flamed maple neck
- Crelecam Ebony fretboard
- Mosaic Pin inlays
- Champagne Gold Acrylic pickguard with rounded and polished edges
- acid etched brass plates
- acid etched nickel hardware
- a relic finish that got a little out of hand
- coil cut, La cabronita wiring with oil in paper capacitors, and solid brass knobs
- Customized zero fret
Everything made by hand, with the exception of slotting and radiusing the fretboard
Probable the best looking effects (non)pedal I’ve ever seen! Are the neck position dots the Japanese knife handle rivet ornaments?
Epic build!
Love everything about it: pickup choices, name-plaques, neck wood-grain... everything.
Wishing you a speedy recovery.
That’s very impressive. You haz skillz for sure. I’ve never seen a bridge pickup like that, how does it sound?
what makes it even more unique, is that pickup is surface mounted. No routing required, just a hole for wiring.
It has a boat load of chime, and even when it’s clean, it almost sounds like it’s approaching breakup. With a fuzz, it sounds pretty fantastic.
I put in a coil cut, and with it cut, it sounds pretty anemic unless it’s behind a fuzz or a good amount of gain. I’ll use the coil cut as 2 gain stages with a fuzz.
