Bricksnbeatles
Member known well
Anyone have opinions on etchants for use on copper clad pcb stock, aluminum enclosures, and brass flat stock? Ferric Chloride? Muriatic Acid? Vinegar-H2O2 solution? Something else?
In the past I've only done electroetching of aluminum, but I have some other stuff I want to work on.
Also anyone have experience using adhesive vinyl as an etch mask in place of toner for certain situations? Dollar tree has circuit vinyl and it would probably be cheaper to do the less-detailed etch projects with that than the comparatively expensive toner transfer paper (never had much luck with the magazine/photo paper method), and my sister has a circuit I could borrow every once in a while.
