bifurcation
(Yet another) weird question...
So... working with a pickup guy, I did a weird thing with my baritone guitar where I had him respin a humbucker so one tiny coil outputs two strings separately so I can run it to a pitchshifter and output that to a bass amp.
I have a stereo jack in my guitar so the blue pickups can be routed to a regular amp and the red pickup outputs to the pitch shifter and bass amp.
(obviously there's some bleed, but I'm pretty happy with the setup)
The one additional thing I've been thinking about is how to wiring up a high-pass filter into a stompbox, so when I turn the pedal on, it'll (mostly) drop out the lower strings to turn the two outputs into a sort of four-string-guitar-with-bass-accompaniment thing.
Long story short, I've been playing with an online high-pass calculator to figure out how filter out everything below the open A string (110hz).
From what I've read, I'm unsatisfied with how shallow the drop-off is, but I've read you can stack filters to make the drop-off more steep.
So (finally!) my question is: Is this a feasible strategy? I know I'll still get transients from the lower strings, but is this a good direction to explore? What would you do? (baring using a seperate output from that top-four-strings partial pickup, because I ain't rewiring that thing again!)
