First amp build, codename “Heavyweight Champ”. In progress.
jcpst
This is going to be a 5F1 circuit, but with a 15w output transformer and a 15” speaker.
After some time considering building an amp, I actually decided that I wasn’t going to go DIY for my next amp. I didn’t want it bad enough yet.
But then there was the sad news that BYOC was going out of business, and along with it a very generous discount code. Knowing that there were amp kits, I checked what was left. I saw all the heavy stuff to make an amp almost like one I was considering- a 5f2 15w 15”. There was a chassis left for a 5f1. That was close enough so I went for it.
I don’t want to sound like I’m all excited I got a deal because they had to close shop. BYOC was such a great piece of the web for quite a while.
From BYOC, I got a 5F1 chassis, PT and 15w OT, and a Jensen P15N.
Once I secured those parts, I ordered a RawCab. He already had a 5F1 15” combo as an option in his ebay store.
Then I got the small parts kit, grillcloth, feet and handle from mojotone.
I got a start on it today. Mounted hardware in the chassis, and placed components on the board. There’s a bit of awkwardness from mixing and matching parts of various kits. I reconciled the difference with a quick trip to the hardware store for nuts and bolts.
My plan is to do a stain. With the TV-style cab, I think it would be cool if it looked like a piece of furniture.
If for whatever reason I decide I don’t like it, I could always wrap it in tweed.
Take my advice for what it’s worth, but I would look into French polishing with dewaxed shellac. You’ve got a cool grain on that plywood, and stain can go blotchy very easily.
Shellac is a strange process when it’s your first time, but you mix the shellac flakes with alcohol, then rub it on with a pad (that’s how I got rid of my old socks).
It takes no effort to get a mirror gloss. You can add tinted shellacs and build color, which will sit on top of the wood and act like a tinted lens.
And the only fumes you’ll get is the evaporating alcohol, leaving it dry to the touch in a few seconds.
It will sand and polish beautifully once it cures for a week, and if you decide to add extra clear with lacquer or polyurethane, the shellac should make an excellent sealer.
… can you tell I’m a fan?
I just finished this walnut with hardware store spray shellac. Definitely takes longer to dry than French polishing. It also took a little extra work with 0000 steel wool and some car polish, but I’m happy with it.
Oh I saw your cab in another thread. That’s beautiful! 😍
Oook. Pretty sure I psychologically shot myself in the foot on this one. No more in-progress threads for me!
I had to take a break from this- I was getting tired of reconciling the difference between two sets of docs and two wiring diagrams.
But, I finally came back to this over the weekend. The circuit is mounted in the chassis, and I have about half of it wired up.
Not in a pretty way though. I either have the wrong tool, or the wrong technique, but I’m making a frayed mess with that cloth covered wire every time I try to strip it. So I think I’ll only address the mess if I’m having noise issues or something.
I’m going to hold off on finishing the cab until some more consistently warm weather arrives.
I’m going to hold off on finishing the cab until some more consistency warm weather arrives.
I think it is looking great. Amps are really satisfying to build. For the cloth wire, I push the cloth back and do not strip the insulation. It will still be a little frayed, but it can work well.
I know the feeling. Sometimes you get too close to it and starts to look like non-sense. That's when I usually start making silly mistakes. I wasted a perfectly good Hammond Chassis a few weeks ago because I flipped the layout in my mind for the controls, but not for the internals. It was all mixed up. I took two weeks off from it while the replacement chassis was on its way, and we're back on track. Keep on doing it. It'll be worth it when you get to play through it.
It can be very good to take a break, come back and see things from a different angle/head-space.
I, too, know the feeling.
My first amp-build was a 5F2A (Champ with a tone control), a CheapAF kit that someone abandoned.
My amp-sifu assigned me to build the kit, but...
The CHASSIS was mirrored to what it should be so I had to flip the layout to pull it together and going back and forth over the way it should be and the way it was... Burned off more than a few brain-cells trying to get The Little Princeton to work. Transformer was dead, and a ... host of other issues.
In the end, I was quite glad the amp wasn't my own 'cause it was so screwed up. Learned a ton.
After turning that debacle around and forcing it to work, the owner never did come and pick it up. That was 2021 — I think that it's still sitting in my Amp Sifu's shop (it was a year ago when I visited).
I then built a 5E3 for myself.
