I'm not normally a bad builder but I went through a phase where I was doing my work late at night and probably exhausted from work. So I've had a pile of PCBs that don't quite work right. Current problem is the Fender Blender PCB. Info here: https://docs.pedalpcb.com/project/Blender.pdf
I'll add a picture of it, but first here is the problem in a nutshell. I get sound and power but, the sound is very fizzy. Sustain and Tone and level pots have minimal to no effect. Blending to clean works, though the clean sound is a bit bassy and not pretty.
I traced the signal path from input and it looks like I get strong signal up to D1 and D2. At these diodes, I have signal at the cathodes but not at the anodes. I checked the soldering at D1 and D2 and that's fine, as is continuity to the base of Q4. Since I am getting input to the diodes, but no output to Q4, I am thinking that the diodes themselves must be the problem.
The diodes are not N34A as suggested because I do not have those diodes on hand--at least genuine ones, I have silicon N34As from Tayda lying around. However, I went with these Russian Diodes that I bought on EBay. I checked the specific ones that I put on the board on my component tester and they checked in at about .3-.4 V. So the Diodes work. What am I missing here? Is there another Diode I should try?
Thanks for your help!
