So I have built the FV-1 Dev board. Was having some issues getting the eeprom programmed so I gave up using the pedal for that and purchased one of these. It worked right away and was able to program a test program successfully. However I am only getting sound out of pin 28 from the Fv-1 when pin 13 is grounded from the stock programs - chorus, flange, and tremolo reverb. does this indicate a problem with the eeprom (SCL, SDA?). trying to get my head around all of this but im thinking is has to be there. I am getting continuity between the FV-1 and the eeprom and 3.3v on pin8 of the eeprom.
edit - should clarify that I get sound out of the pedal when pin 13 is not grounded but it is just the dry. turning up the mix lowers the volume since nothing is coming from pin 28.
