fv-1 sound samples
srf86
I'm looking into doing a few fv-1 based builds. I appreciate that the dmd-2 has a short sound clip, I would love to be able to hear what the other algorithms sound like.
the_grumpy_gnome
This Octagon build covers many:
The Kaleidoscope is near identical to:
Check out "PEDALPCB" & 'FV-1', 'Octagon,' 'Pythagoras,' 'EEPROM' etc on youtube.
I'd recommend building an Octagon and use the EEPROM builder for effects you're interested in: Basically all the FV-1 PCBs are identical and you swap out EEPROM chips. I did so and as to be expected, some effects I use and some I don't, but the ones I use are amazing. 'Kaleidoscope' is a fav
srf86
thanks the_grumpy_gnome. I found pedalpcb.com shortly after I found Bugg FX daydream. The Kaleidoscope looks like it would be a really fun pedal. I'd love to be able to add a secondary footswitch to a fv-1 pedal for tap tempo, but from what I've read that is often done in the code.
I am excited about the the potential of an fv-1 and relay switching acting as a momentary switch!
the_grumpy_gnome
Yep. Of note- there's a PCB available specifically for the Daydream.
Oh yeah, tap tempo on FV-1 would be awesome. Judging by some of the forum discussion recently it may show up in the nearish future
