i've been begging for something like this for years. was going to start throwing ideas at a wall on a breadboard to try to figure it out, but if someone wants to just trace this one instead
@Robert just sent mine back to me. Pretty sure he traced it.Omnilooper is cool.
"It consists of three effect loops (Inserts), two of which are equipped with filters (1x LPF/1x HPF) with -12dB/Oct. per Filter. The filters position in the chain can be switched (Filter -> Insert, Insert -> Filter, or Filter off). If turned off completely, three parallel fullrange effect loops are possible. To be able to use even effects which are normally only utilizable directly in front of".
And it has a Bass-EQ (bass boost only, 60Hz, Bell-EQ), who-hoo, more here.
that thing is way overkill. super rad design. 65 dollars for a PCB with a lot of features i'd never use. it would be a lot more useful for me to have something simpler like this great easternOmnilooper is cool.
yeah, i've got a couple. not enough control. need a variable crossover. the plan is to end up with something similar to the darkglass X series.Have you checked out Fuzz Dog's Fat-Ass Blooper?
Blends clean signal with whatever's in its loop and has a toggle-able low-pass filter on the dry.
It's just missing a phase switch, unfortunately.
Available as a kit or just the PCB...
