Help Wiring 2-in-1 Pedal
Any Idea how I could wire these two pedals into one enclosure without 3PDT breakouts? The 4 wires at the bottom of each PCB are (in order from left to right) Input, +9v, -, Output. Also would need to include an LED in there somewhere since these PCBs don't have LED pads. Thanks!
There’s a great page with several wiring layouts here:
I've looked at those, it will work except the pcbs I'm using only have one ground pad, no LED pads. I've got it working but I am not sure if I have it set up the best way. There's a ton of offboard wiring the way I have it now. I've got 4 wires from the + of the DC jack running to the two LEDs and + pads on the 2 PCBs. And I'm not sure I have the grounding set up the most effective way.
