Help with Blues Jr STANDBY
Just turn the "master volume" knob all the way down when not playing, it's better for the amp...
But if you insist, locate the 2 red wires coming from the power transformer. Cut ONE of those wires in two. Attach one of the red wires to one of the center lugs of the switch. Attach the other red wire to either of the side lugs ON THE SAME SIDE as the center lug you soldered the other wire to.
Good luck
I saw this on internet, but I´m not sure if it´s ok
