I am almost finished my hydra build and scouring the forum for design and mod inspiration. Your build is awesome. I love how all of the nuts on the switches line up (not sure if that was intentional).
Mine is in the mail somewhere... can't wait!
If you’re just soldering a single smd chip like on the majority of FV1 boards, your easiest option is probably to just get some solder paste and a cheap toaster oven that you use only for non-food stuff. It’s super easy that way, and you can also use the toaster to cure paints and try DIY powdercoatingI’ve seen a few SMD soldering tutorials and they make it look so easy but I haven’t tried it myself either. Seems you are okay with your normal soldering iron tip but it’s good to have quite fine solder. I didn’t fancy testing my SMD soldering on a $18 dollar chips so I had mine pre-soldered too.
If you're confident with your soldering, you'll be fine with finer solder. I did a full on SMD project and it went great for the best part. I almost ruined a chip I paid too much for (reflowing it when it wasn't the problem...), but all was working in the end.I’ve seen a few SMD soldering tutorials and they make it look so easy but I haven’t tried it myself either. Seems you are okay with your normal soldering iron tip but it’s good to have quite fine solder. I didn’t fancy testing my SMD soldering on a $18 dollar chips so I had mine pre-soldered too.
