visualdistortion
Hi, I did the Hylian Fuzz, all is wired correctly, not a lot of components, volume is HUGE but the control pot do litterally nothing on sound, or maybe a bit at one of the extreme. Anyone got the same issues? Thanks
The control knob should go from gated and farty ccw to wide open pulse wave type sound fully cw. I've tried to build a couple of these and couldn't get them to work like the originals. same type of issue you are having. I used to build these on contract for the company and we used generic parts and got the correct result every time.Hi, I did the Hylian Fuzz, all is wired correctly, not a lot of components, volume is HUGE but the control pot do litterally nothing on sound, or maybe a bit at one of the extreme. Anyone got the same issues? Thanks
the Silver Crank is the same circuit as the 33. just a name change. Devi didn't know how to read or write schematics back then and I know that a huge packet of schematics and design elements was compiled and shared by her forum members, but most were attempts at using design logic (which devi had none) to figure out how to wire them up. They were all direct wired etched pcbs that were wrapped up in electrical tape and left flying in the box. There were no BOM or schematics to work off of, just a simple hand drawn diagram that showed where the wires attached. I remember it being a very strange configuration. The Hyperion and Ruiner were made from two cascading circuits wired the same way as well. The JHS Astro Mess was copied from incorrect online data about the Hyperion. Googling Bit schematics gives like 5 different interpretations, some with the extra 100nf/10k, some without. I wish I still had my notes on this one.Now I'm curious about how accurate the schematics going around actually are...
The PDF released by Devi (where I suspect these schematic originated) specify that the LoF was a Silver Crank > GZ, but like you mention, it doesn't specifically say which controls are in use on each of the two circuits.... so was this just "assumed" on the existing schematics?
If what you say about the controls is correct then the available schematics are wrong. They put the Control pot on the input of the 33 and the Volume on the output of the GZ.
I don't see the elusive 100nF / 10K, just going by the schematics of the individual circuits, but again, that's assuming they are correct...
I did some test again on my real amp, and yes it's like that, so I think that something is faulty hereSame here. What you're describing sounds exactly what mine was doing as well. No sound for part of the sweep and then little sound up till the pot is maxed out. Then I have to strum very hard or place a boost before it to get any sound of "good" sound.
like a 180 degrees?Anyone want to try an experiment?
Remove the 2N2907A and install it backwards (so the metal tab on the transistor does not line up with the tab on the silkscreen).
Im down. Ill try it here in a few and report back. Unless @visualdistortion beats me to it.
I use Les Paul with sh4 pickup, I really tested and looked some videos and a lot of people have sound on the ”1” position and have sustain, I really don't have sustain on it. I did a video, I will upload in few hoursMy 2 cents for what it's worth. Flipped 2N2907A and its def a more usable pedal for me. I would say 7-10 o-clock almost nothing. 10-11 o'clock is pretty gated with 11 being the "video game" type tones you'd expect from this pedal. 11 - 5/5:30 o clock gnarly fuzz tones and very loud! I had it at 9 o'clock and I almost killed my dog though my twin reverb. For what it's worth too I'm playing through an SG with humbuckers so I imagine if @visualdistortion is doing single coils he'd had different results.
