Hello all,
I am having a strange problem with an Oasis I just built. The power works, the sound passes through when the pedal is off, the LED lights up. So the wiring appears to be ok. So this happens. If I turn it on, it will make an overdrive sound for a few seconds then change into harsh static that turns into quiet. While like this if I touch the Volume pot you can hear the radio through the amp. If you turn it on, or plug unplug it stays quiet. If at this point you replace the chip it starts the cycle over with the actual overdrive into static, then nothing with radio. Swap the chip back to the same thing. I replaced some capacitors that were near where I soldered the switches in in case they got cooked.
Thanks for any help!
