Issues with Cliche
iandunham
Hi All,
I'm wondering if someone might provide me with the routing for the switch PCB wires. I'm having some issues with the pcb itself for some reason.
There are 6 wires, I know some other PedalPCB are have the convention like this:
Is that the case of the Cliche?
Another question: I think I toasted the dual gang B50K pot, and all I have around is an A50K single gang pot. I just bridged the two sets of contacts on the pcb, is there a problem with that?
Thanks!
Thanks for the quick reply, Robert.
I've now put in a B50K dual gang pot, and wired the switch like above. The circuit passes audio when off, and when on, the dual gang pot behaves in the reverse of how it should: turning it down all the way increases volume/gain, and turning it up decreases the volume/gain.
Any likely culprits for this?
Please post photos
Sorry about that - here you go.
It looks like you have a few cold solder joints on the dual gang pot. Maybe try reflowing the pins? Robert already mentioned this but your dual gang pot should be Linear 100k not 50k.
