Hand-did artwork is the best! I think I see what you did inside. The SLAM switch kicks the feedback up by an amount set by the added trimpot. The SLAM switch is momentary, right?
Please share how to SLAM
Are the led bezels mounted outside the box?
I use these for all of my builds. You just drill a 1/4” hole and push them in and the led hold them in place. They work great!
I mean, the way it was mounted on the picture. I think the bezel wasn’t pushed in enough. Half of the bezel is still outside the box
what kind of momentary switch should i use?All you do is wire a momentary switch to lugs two and three of the feedback switch. When depressed it will be the knob setting and when stepped on it goes balls out. You can add trimmers or pots to control the speed of it if you want to get crazy.
This one I believewhat kind of momentary switch should i use?
You do, i am working on my secondI don't know how I missed this post the first time around but this is great! Maybe I need to build a magnetron
Yes it will with most pt2399 if not all.Does that slam switch mod work on other delay circuits?
