Chrisq206
Are the channel switching relays in Soldano, Bogner, Tone King amps latching relays?
I can use my Carl Martin Octaswitch to switch channels In the above amps using a pair of triggers in the unit and I’m looking to build a relay loop box that I can also turn off and on with the the same triggers. The idea is to be able to control pedals in the FX loop of the amp as well as the pedals in front of the amp The BYOC relay module box I built doesn’t work properly, I’m guessing because it’s non latching.
I suppose the switch would have to operate on the same principle as the internal amp relays.
Which, if any, of the relay modules could be configured into this type of box?
Cheers,
Chris
Cheers,
Chris
