SOLVED Leprechaun signal issues
Jbanks
Hello all,
completed the Leprechaun. I get the same bypass signal in both on and bypass. The Magin button is working and going nuts when I turn it on, so it’s the main fx signal path not working.
when I run a audio probe, I get to the last pot (Tone/Regeneration) it can hear the pitch and effects all working fine when I tweak the pots. However, as the signal leaves somewhere after the pot, I’m losing the effected signal path. C9, R13, IC1, R8, and C4 to the output all show a clean unaffected signal.
Any ideas on what’s keeping the affected mix from being added to the signal? When the output comes back to the 3PDT it’s clean as well
thanks
James
