JamieJ
Still searching for my favourite overdrive…
This one sounds pretty cool. I haven’t played too much with it yet but it seems a pretty decent sounding pedal. For some reason I have put off building a TS based pedal. Not sure why but thought this one had some extra interesting features including the switch and the body control to be worthwhile. I can't believe the actual pedal is going for $265.
I had some troubleshooting to do initially when the relay bypass wouldn’t turn off. I cleaned the board again, reflowed joints and checked values and orientation but no dice. It turned out it was a defective NE555 IC. Now it’s working perfectly with a replacement.
I could only get hold of a W20k pot instead of a W25k and I used a C250k pot with a 390k resistor between lugs 1 & 3 which gave the pot a value of 143k instead of the C150k. I also subbed the tantalum caps, as I couldn't find that value anywhere online. The glass/stock/edge switch is pretty useful. I am due to place an order for some faceplates for my most recent builds so I will see if i prefer this bare or with a faceplate.
