Madbean Current Lover Matrix setting not working
Chrisq206
I’ll just say I and so happy this build is finally working. It’s been about a two year battle of attempts to fix it, putting it away, then having another go, and so on….
As of yesterday the regular flanger mode seems to work as it should, but in matrix mode there is signal, but no effect. It sounds bypassed, but it is the same volume as the the flanger side, so it’s probably going through the boost part of the circuit. It was suggested I move the knobs to see if it is functioning. I did and they didn’t do anything.
As part of getting the pedal to work in the first place I changed the wiring from the regular non effects loop wiring to the the effects loop wiring, but with the effects loop still bypassed (I hope that makes sense). I was getting oscillation with my initial wiring when the output jack was grounded to the chassis. I could not figure out why and decided to see if it would work if I wired it in the effects loop configuration, but still bypassing the loop.
Suggestions?
