SlowAudio
Hi all. I am new here and this is my first post.
I built the magnetron delay and tested it using the auditorium platform. It worked in the test. However, I noticed the bottom LED was a little faint. I figured it was because I just stuck in LED in there to test, and the connection was a little weak.
I boxed it and it worked great, except that the LED that indicates rate did not work at all. I used a ring LED foot switch. I took it apart and tested the LED. It works. I have continuity on my DMM from the hook up wire to the other side of the board for both wires. There does not seem to be any power coming through. More accurately, it’s a very low number that hovers around 0 V. Posted a pic but the hookup wire in on the other side so I can more easily solder it to the ring LED pcb.
I’m very new to pedal building and electronics in general, so I’m not sure what to do next. Appreciate any help. Thanks!
