So I built this pedal like a year ago and it’s always worked great and I like it a lot but I unboxed it to spray paint the enclosure the other day and now when the switch is on the low setting the volume drops like 90% and you can barely hear the signal. Hi setting works.
could it be the switch is bad? Also I swapped out the TL072 and now it’s distorting like an OD (a bad one). I probably shouldn’t have swapped it I was just trying something thinking that IC was connected to the hi lo switch.
anyways TIA
anyways TIA
