Mammal works but won't shut off go to bypass..
Mourguitars
Wired this pedal up , plugged the power supply..no LED working, so i touched another LED on top of pad (reversed ) from here like symbol 3 and it worked on and off like it should with the switch..so i installed a new LED that way and it shut on and off...ok....
Plugged the pedal in and it worked like it should sounded great with very little noise like people complained about unless you dime the volume and gain got feedback but thats normal ...but when i press the 3PDT off the LED stays on and no sound when your guitar jacks are plugged in...unplug the jacks the LED goes on and off like it should...So in other words it works, click the 3PDT and is mute with LED still on...Hmmmm
LED goes on and off like it should...with no jacks
Plug jacks in the LED stays on all the time , but have sound then click goes to mute with LED on..
Mike
Lol....i ordered the wrong ones !
I thought something not only looked funny , i thought he may have changed them...the last one on the Muffler was loose and this one fit or snapped on tight....ill just hard wire it to the 3PDT, this last order i bought the one you can run wire thru
Thanks for the reply, I've looked over every solder joint wiring...lol
You the da man DGWVI !
