DeadAirMD
Just built the Collosalus and was stoked to fire it up since I've always loved the MXR 117.......and it literally "fired" on up.
As soon as I engaged the pedal, I was only getting clean signal. Started to mess with the trim pots and smoke started coming up from the 22R resistor. Thought it was a bad component, so replaced it and the exact same thing happened again. The only component substitution I did was two 22uf 35v caps for the 15uf 25v caps. Pedal is running on 18v 100ma. What the hell did I do wrong!?!?
