mybud
Dear forum folks: Greetings from South Africa.
Just finished the Mesmerizer build. Strange symptoms as follow: The LED responds to changes in rate and depth, the volume pot also responds, signal is mildly amplified, but the only way to get the mesmerising aspect is by touching the board in the area of the 5457s. If I do this, it seems to function properly.
What's really strange is that the reading from the charge pump (positive side cap 19) is approximately 14V. I saw from an earlier post that this should be closer to 18V. I've tried three different charge pumps accordingly (TC1044SCPA and SEPA and LT 1054).
I wish I had socketed the transistors as I normally do, but I was itching to hear what this baby sounds like. You'll see that I replaced Q6 already (rather shoddily), thinking that it might be a dud 5457. No change in behaviour.
Any advice gratefully received and best wishes to all, Marc
